here's mine...although it's more of a street truck.
mild 383 stroker build, managed to squeek out a 505hp on the engine dyno, but realistically it's probably making 475-480 at the crank as it sits inside the truck, and likely only putting 400-ish to the ground.
truck weighs 4200 lbs with me in it.
pretty slow too. 13.9 ET @ 103 MPH. if I get it to hook, it should be low 13s, and if I'm lucky, high 12s.
full street trim, full interior, all stock sheet metal, stock suspension, with hotchkis 2" drop coil springs and 3" drop leaf springs.
4.56 gear'd Detriot true trac in a 9.25" axle, and a TKO-600 5 spd with .64OD make it fun to play with, and still cruise the freeway at leisurely RPMs
**Photobucket sucks**
