There are serious problems with that test.
It doesn't show how to use a manifold. Like the low compression/ high vacuum engine benefiting from a performer, over a high compression working with a high rise open mnai. Both can shift quite a paradigm, with just single or dual plane manifolds.
All those tests are around 10 hp/lbs apart. Not realistic to me.
