I did a swap from a set ported 906 heads with 2.14 and 1.81 valves to a set of CNC ported Eddy RPMs and gained 2/10 and 4 MPH I beleive the stock out of the box B1-BS are better than the stock Eddy RPM as far as flow, my stock OOTB Eddy RPMs outflowed the ported big valve 906 heads
