IF your not using vacuum advance then pin the plate. only way to be sure it won't move.
i wouldnt mind doing that. whats the best method? i tried welding it but it was a cf. the plate rides on brass pedestals as its contact points so you cant weld those. i tried welding the pin that the plate rotates on but the weld didnt hold very long.
this was on an old distributor that i experimented with
It's got a cop motor, a 440 cubic inch plant, it's got cop tires, cop suspensions, cop shocks. It's a model made before catalytic converters so it'll run good on regular gas.
