Thats a fantastic budget camshaft! We used it in my brothers first small block. It shifted at 7200rpm with a 3.79 stroke. It also had box stock edelbrock cylinder heads and an M1 manifold. The car went 11.09 @ 118mph with that cam. With a 3.58 stock stroke 360 it should be more like 7400-7500 RPM with the similar parts used. It sounded great as well. Im not sure how well it would work in a heavy vehicle though.
thats a bunch more RPM than that cam likes
my 69 dart 2970 lbs W-2 318 only turned 6,700 RPM to run 10.9s @ 121 the same cam in my 360 liked about 6,600 RPM ran 6.6s @ 104 1/8th its a nice cam makes good power for what it is and is verey mild manered if you want to run it on the street
