Quote: I have one kinda crazy question, what is the distance from frame rail flange to frame rail flange above the spare tire?
Mine shows 33 7/16" as shown in the picture.
The outside of the frame rail to the outside of the frame rail is 38". The perches mount to the outside of the rail. If you need the distance from spring to spring it is 40 3/4" inside to inside. If you need other measurements, let me know.
