Well, upon further inspection and testing it appears that I have a 69 1/2 engine harness on my vert. The open, round female connector laying on the pass side of the intake (18ga dkblue) is in fact the dbl wire coming off the double wire field terminal of the alternator. So I guess I'll go with that. Is there someone that sells the wire that connects that part to the solenoid? Thanks.
