that looks pretty normal. a simple freshening is obviously in order but the camshaft should be replaced IMO. i'd check the bottom of the lifters to see if they are still convex shaped. looking at the worn lobes, some of the lifters might be flat or convex now. how do the cylinder walls look? timing chain stretch? valve springs and guides???, etc. etc.
