Is there any of the stud protruding from the hole? Even if its just a little bit?
It would be easy to take a 5/16 nut and mig the stud to the nut.Heat the area up around the stud and it will fall out.
If nothing else its possible to blow the stud out with a torch set without hurting or burning the head.
[color:"red"]65 Hemi Belvedere coming soon [/color]
[color:"#00FF00"]557" Indy engine 1.07 60ft 144mph in the 8th 2100 lbs package [/color]
