and theyre annoying me.
setup is the fully coated and polished tti step headres for a body, bolted to indybrock heads with stage 8 locking header bolts.
both the collectors and head flanges are leaking. i purchased some copper gaskets from summit for replacement.
what install practices for the copper?
rtv?
torque spec?
tightening pattern?
other suggestions?
this is the third set in 2 years and 2000 miles. im starting to get annoyed.
michael
Michael Crawford CSP 1970 plymouth Duster back under construction: http://www.pro-touring.com/showthread.ph...ouring-makeover 1964 el camino beater shop truck 96403-project-drivabeater-2-0-64-el-camino-this-time
