having had a good running ford engine to test the carb and the problem followed the carb, it's probably a safe bet that the problem is with the carb only.
but...just to be sure you're not fighting 2 problems at once...do you have another carb you can put on the 440 to see if the 440 will run on it's own?
**Photobucket sucks**
