Most rebuild kits come with an assortment of gaskets so one kit will do a multitude of 4150/4160 Holleys. Some one may have done a poor job of matching up the gaskets. Take it apart and see if any of the passages are being blocked.
The kit comes with two body gaskets, maybe the re builder installed the wrong one.
All passages line up correctly for the gasket between the main body and the metering block on the primary side. On the secondary side there is a gasket that is blocking two holes, but im not sure if its possible that it should be blocking those holes. Also, since that is on the secondary side I wouldnt think it should be effecting anythiing when the car is idling or revving up in park.
Now I need to pin those needles, got to feel that heat Hear my motor screamin while I'm tearin up the street
