More grinding, priming of the trunk area. You can see on the rear floor section under the glass. It has a lot of pits. This piece is removeabe & I figured my parts car one may be in better shape. However I decided to use this one since it will be covered with carpet. I took it down to bare metal. Primed it good with several coats & time between coats. It was the wet carpet that did this I'm sure.
