I have reused street Hemi rods when I first started racing that had spun a bearing inside the rod but not overlap them and did not turn the crank and rods black they did have minor heat discoloring but not severe The big things is to have them magged first and then how much shorter can you stand for the two recondition rods to be versus the other 6? Those two replacement Child and Albert rods will be hard to find now
