Here's the recipe: Magnum heads with tight quench .030. Bowls opened up. Stock valve job. Wiesco dished pistons Mopar Performance M1 Dual plane intake Roller cam Compcams #20-000-9 506 lift 216 intake 224 exhaust duration. Mopar orange box. 340 HP manifolds with a TTI 2 1/2 inch exhaust system. Distributor that I recurved for timing all in at 2000 RPM. This is a big one: Thermoquad 850 carb. Best carb I've tried and I've tried them all. 700R4 Chevy trany with converter lockup. But any overdrive trans would work. 3.23 8 3/4 rear end Aluminum radiator with electric fans. Fans don't operate at anything over 40 MPH so you gain at least 1 MPG with that mod.
one question: are you running an adapter for the t-quad on the M1 dual plane, or is it capable of bolting up a spread bore?
some thoughts on the combo, it sounds like a real fun street combo, you could probably get a fair amount more power (~20-25HP & TQ) without sacraficing fuel economy (maybe even help a bit) going to headers.
you're leaving power on the table with the stock valve job in the magnum heads. it's undersized from the factory, and there's gains to be had to opening it and the pushrod pinch up (probably ~40-50HP)....would be interesting to see the power/economy difference with some lightly massaged EQ 318 (hughes "iron ram") heads or RHS heads
from what I've heard the M1 leaves something to be desired as far as performance, that it's essentially no better flow wise than a stock piece. would be interesting to try an LD340 modified to fit the t-quad....that might net you another 15-20HP....
I've thought that comp cam (XR265HR) would make a nice street cam for a small block....it must idle pretty much near stock with 408 cubes under it.
best I've managed so far with my 318 is 18mpg...combo is stock short block, home massaged magnum heads, reground cam by bullet cams, 259/259 adv, 208/208@.050, .316" lobe lift, .506" @ valve, headers, 3" single exhaust, RPM air gap, eddie 1406.
tranny is an A500, rear gears are 3.55, tires are 27" tall...car is a 5th ave, 3950lbs w/o me. I think my carb is what's holding my mileage back now...I haven't done an all highway/freeway trip, I'm guessing it'd hit 20.
1976 Spinnaker White Plymouth Duster, /6 A833OD 1986 Silver/Twilight Blue Chrysler 5th Ave HotRod **SOLD!*** 2011 Toxic Orange Dodge Charger R/T 2017 Grand Cherokee Overland 2014 Jeep Cherokee Latitude (holy crap, my daughter is driving)
