Any "easy" way to get these bolts out? I was able to use my cordless impact on a few of them but the ones I need to to do by hand are STUCK ideas?
use a 1/2" breaker bar & a cheater pipe on the end of it if needed. maintain the socket/extension in line with the bolt head (pretty much vertical) & the breaker bar/cheater out horizontle at a 90 deg angle & jerk the handle rather than a steady pull to break (em) loose
