Two of the big thing in a succesful head gasket replacement one is cleanliness and the other is making sure that the head is true. Thake it to a good machinist and have him check it and make sure that it is perfectly flat. The head is the most likely to get slightly distorted.
Clean it, if it's Dirty. Oil it, if it Squeaks. But: Don't fix it, if it Works!
