Glad to see it picked up as much as it did, as I know your "hand ported" -1's were not your basic run of mill port job. Glad that the effort was worth the reward.
Thanks Ryan, Im glad I went the route I did. I put the cam in @ 104.5 (5.5 degrees advanced) and it moved my power band down to a managable 7400 rpm shift point (Peak power was @ 7200). It was the most power put down on their dyno by a 410" or smaller motor that was N/A so far. The only ones that made any more were 434" or larger with exotic heads. None made any more power per cube than mine did and Im running a shelf cam from Comp. They were impressed to say the least and I was very happy
