I've written a bunch of articles on similiar combos, you can find them on this board or on the net. I also covered the topic in my book.
Short answer is that combo will work just fine as long as you use the correct camshaft. The Mopar Performance .528 solid will work great or call Dwayne at Porter Racing Heads for a specific recommendation. The vast majority of "catalog" cams will not work very well for that application. Most catalog cams have too much overlap to work with exhaust manifolds and you'll end up with a dog. The correct cam will make more power than your chassis can handle.
