ive thought about ,,what if a pacifica,front stub could be swapped in to a street rod,,v-6 modern injection,all in one piece being swapped,,,,but im sure its track is too wide,,,
I've thought long and hard about this type of swap too. I have easy access to low-mileage wrecked cars for cheap (Intrepid/Concorde/300M with 3.5 liter or minivans with 3.3/3.8 all selling for well under a grand). The biggest draw is the "drop-out" style of the engine/trans/steering/brakes. The biggest drawback is the clearance needed for the upper strut mounts.
'99 Caravan 3.3 heavy damage on both sides. Runs/drives. This one has 130k but that's nothing for this drivetrain and the rod it's going into wouldn't likely see a lot of miles anyways. This could be in my shop tomorrow for $400. Hold out for lower miles and harder wrecked and the price wouldn't change much. It just kills me to not be able to use the simplicity of this drivetrain swap.
