I'm in the middle of building a 451 right now. 400 block from craigslist $60 (thanks Doug), steel 440 crank $100, 440 rods $20. KB 280 pistons $300+. will be bored/honed, balanced, mains turned, quench pad machined. Only big expense will be the heads (915's) as quench is a must and I'd be better off just biting the bullet & springing for some stealths.
Robert, Are the Stealth's going to cc just right with the KB 280 pistons? What cam are you planing on? Sounds like a good write up for a Mopar mag. doing a budget build. With the right cam, it should make well over 500 HP.
Snap your neck, mega G-force launch, is all I want!
