Thank you
FYI
I have done some additional research and found the following
Fuel injection tips: use an alternator newer than 1990. If you are building a Mopar use the Denso unit. Its not only about amps, the alternator must control the voltage spikes so the ECU will not be damaged, older alternators are not designed to protect the ECU.
http://www.rushpowersystems.net/?p=6
1970 Barracuda Convertible
1968 Satellite Street Strip car
1654.5 Mustang
1955 Land Rover
