Quote: Ran 8.70's with a stock block 400/499 with Indy 440-1's on spray, Dart weighed 3450 with me in it. Tall fill, Pro Gram caps, Oliver rods. Wound up hurting the pistons in it but thats just because they weren't set up for spray. If I was to do another stock block, it would be with aluminum rods and main caps.
That's what I'm talking about How much spray were u using if you don't mind sharing I was wondering if anyone on here was running in the 8's with a stock block at 3300-3500 lbs.Thax..
