Ever consider just getting a 360?
A 360 crank in a 340 is the same as a 360 with a .040 overbore.
yes, i'm just covering all options. i'm trying to find an older 360 block. i really want to do a stroker but won't be able to afford it this year so i wanted to freshen up and gain as much cubes for cheap.
if that's the case I would just look for a good running 360 and do the stroker over time ?
