just an observation, but isn't the Stuska dyno the one you normally test on?
I have used that dyno twice on two of my motors, the 518 pump gas motor six pak motor and this one. I did test one of my other pump gas six pak 464 C.I. motors on a DTS dyno in Corvallis,OR last summer. I was not impress with that facility so I haven't went back to use it again since then and I won't use it again.Dram read my edit update on the first post about another difference between the Studka dyno room and the DTS dyno room and give me your thoughts on that please
