I have a stock suspension Duster, i have been able to fit 10 inch wheels with 5.5 bs and 28 by 11.5 QTP tires(true 10 inch wide)...you need wheel spacers to do this.. i had my dana made .5 of an inch wider per side to get rid of the spacers i used with my 8.75 rear.It will work like i currently have it with wheel spacers..going from 8 inch to 10 inch wheels made a huge dfferece on my high 9 sec car....
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam Best so far, low 10.30’s 1/4 1.41 best 60 foot 6.56 at 104.17
