No it has to be there for clearance. Measure the width of a 727 tail housing where it passes through the crossmember and then compare to a 518. Big difference. You have to make the tunnel wider at this point. I have seen pictures of guys using square bar, looked too boxy and they really had to cut into the floor, the round bar is a little less intrusive. Good luck!
