There's no way I could tighten it anymore without breaking it. I ordered another one so maybe I'll do a little experiment with the old one.
If you can't tighten any more i would check the thread on the pump,If everything turns out good and you want added insurance i have seen guys tack weld the pick up.
Also when you found dropped the pan could you move the pick up by hand??
