I do not have the cam card, but I believe it suggests .016-.018 lash.
This sound right...
Brand: COMP Cams
Product Line: COMP Cams Xtreme Energy Camshafts
Part Number: CCA-21-232-4
Cam Style: Mechanical flat tappet
Basic Operating RPM Range: 2,500-6,500
Intake Duration at 050 inch Lift: 244
Exhaust Duration at 050 inch Lift: 252
Duration at 050 inch Lift: 244 int./252 exh.
Advertised Intake Duration: 282
Advertised Exhaust Duration: 290
Advertised Duration: 282 int./290 exh.
Intake Valve Lift with Factory Rocker Arm Ratio: 0.520 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio: 0.540 in.
Valve Lift with Factory Rocker Arm Ratio: 0.520 int./0.540 exh. lift
Lobe Separation (degrees): 110
Camshaft Gear Attachment: 1-bolt
Intake Valve Lash: 0.016 in.
Exhaust Valve Lash: 0.018 in.
Computer Controlled Compatible: No
Grind Number: CRB XE282S-10
