Quote: If you put 17 inch wheels on there then you can run Viper brakes. Here is a local '68 Valiant running at PIR with a Viper conversion kit on it.
If you are going to get bigger rims/tires I'd go 17" for better choices and possibility to grow into bigger rotors (13") and calipers (big Brembos or 6 pot Willwoods)
