Re: Carb running rich
[Re: PlumCrazyCharger]
#465122
09/11/09 10:51 PM
09/11/09 10:51 PM
Not sure about the 18 degrees. I checked my timing and it's 10 degrees diff. 24 at idle and 34 at 2000 RPM. Let you guys know on Sunday how it works!
at 2000 rpm your probably not at full advance yet. i'd check it at 3500. also, you shouldn't need 1.5 turns out for your combo at idle on all four screws. you've made it idle better, but i bet you can still improve on that.
