Now I will confuse everyone with this, In the mud I have never seen anyone shift fast enough to keep up with a auto trans, most manual shift trucks fall flat on the shift, the resistance in the mud is grater than pavement and instantly slows down the drive line dropping rpm too much on clutch release, this factor must come to play in drag racing to some extent Just something to kick around
