That is one way to solve it, but before you get your drill out, adjusting your secondaries open a bit more (set screw in carb base, access from the bottom) might just solve your problem.
I have an 850 Holley on my 440/'71 Charger, and I went through this same situation around 7-years ago.
The purpose of drilling the holes and/or adjusting the secondaries open more at idle accomplishes the same task, allowing more airflow at idle. This is done to compensate for the weak signal (vacuum) produced by long-duration/high-overlap camshafts.
That said, don't open them up too much either. Here is a quote from Holley:
You should not see more than .025"-.030" of the transfer slot exposed past the throttle plate at idle.
The "transfer slot" are the slots machined into the base-plate throttle-bores.
In a "Normal" street application, the idle system works like this quote from Holley.com:
IDLE SYSTEM
The idle system supplies the air/fuel mixture to operate the engine at idle and low speeds. Fuel enters the main well through the main metering jet that is screwed into the metering block.
Some of this fuel is then bled off to an idle well where it is mixed with air from the idle air bleed hole. The idle well leads directly to the idle discharge port and the idle transfer system where this air/fuel mixture is discharged
Of course, your situation is "different" and not a "normal" street engine application. The Holley website "used" to have the information on why/when/where to drill throttle plates and/or secondary throttle-blade adjustment, but it was either eliminated, or it's buried in their site.
