Swapping from a 750 holley to an 850 holley that i just purchased. I noticed the 750 had holes drilled in the front butterflys. The car has a larger cam so i understand this was done to assist with idle. Since the 750 had the holes.should i have the 850 butterflys drilled before installing too?
