If you have the toe at zero static you are probably getting some toe out down track which could make it unstable at speeds. I would set it at 1/16th toe in on each side.
Bill... the worst thing you can have is toe
out, the car will start to dart back and forth, the
more its toed out the worse it gets... can you get any
more caster
