I don't know what your putting it in but the first thing I would do is turn the front 3-4 gear linkage arm so it face's up. Next thing you need is a bolt in the hole at the top of the shifter assembly . It's the main bolt for holding the shifter.
it's ok to butt heads, just don't do it with a butthead
