Are any of you using E85 fuel with Eddy carbs and or the Carter carbs that are plated like the newer Eddy carbs are? If so what jetting and needle and seats are you using? Also what about the acelerator pumps? will the stock ones Eddy uses work or do you need to replace them with a different type? Thanks in adavnce, one of the local Mopar NSS racers needs to know
