Sweet looking setup! What I was thinking for mine is more of a front-mount TB to keep things under the hood like a TPI intake. Just hoping to be able to use as many shelf parts as possible to keep the fabrication to a minimum. If you can get the typical manifold heights at the front and back ends of the manifold, that would be a big help.
Thanks!
Clair
