yea, didnt you put this in a car about a year ago?
All the coil needs is cool air over it at all times while engine is running, if you can make something that does not get in the way of the air flow and does not put more heat into the coil, it would work. what that is, idk. i will look at my spare engine and see what i can come up with.
