At 2800 lbs you should be well into the nines.
4.56 and 31" tire will work good. I think the cam is in need of improvement,
5300-5400 for converter would work better too.
Opps, misread it. Thought it said 33's. I still would have went 4.88 even with 31's. The 4.56 will suffice, but the converter is light, the intake is all wrong and the cam is so 20 years ago
