did the UV dye show leaking from the seal area?
since it is out, check the converter snout for cracks.
Yes there was definitely a trail leading from the seal area.
No cracks on the snout however there is some significant wear on it where it would presumably sit against the bushing (can see some bronze showing through in some parts). And if you run your finger over it you can tell where the groove starts if your eyes were closed.
