It is a six finger single disk slipper style clutch. It has a 130 tooth flywheel and will fit into a Lakewood bellhousing. The ad below says it would fit into a stock style housing. Personally if you are making that much horsepower I would want an SFI approved bellhousing anyway. It can be expanded to a dual disk clutch. $1950.00 out the door and into your car. Here is an ad for the clutch. Sorry it is in chevy Max online magazine.
Boninfante Clutch Ad
