I'm not understanding what bolt your talking about. As far a setting both bars left and right level with the ground, the drivers side has no slack, the passenger side is pre loaded two flats, now with footbraking the shocks are set on 7, with the brake I set it at 4.. You may have to play around with tire pressure also.
