Hello,
I'm getting ready to put my transmission and engine together and into the car. Still deciding what convertor to put in.
I have a factory High Stall convertor out of a 78ish maybe 79 Aspen R/T with a 360.
My engine is a 76 440, and the trans is a 73 727.
I can see splines clear to the end of the convertor.
That will go right in right? There isn't a chance that it is a lock-up or something is there?
I am using a B/M (I think) SFI flexplate and I want everything to go together smoothly.
Thank you, ROB
