what clutch are you using? centerforce dont really need one. i have left many out myself. i thought if you unhook the clutch,and depress the pedal alone,you can pop it on w/ a small prybar?..then pull it up,and rehook the clutch linkage. be careful,and not get your fingers pinched under the pedal,once the spring is attached,w/o the linkage attached,lol..SLAM!! OOOWWWCCCH! F%$$^ D%$#^ S(%^!!
