A piece of foreign material or a component failure has allowed the check valve in the lifter to remain open.MAKE SURE THE OIL FEED HOLES AREN'T PLUGGED WITH CRAP........if you can access them you may be able to clean them out with compressed air, carb cleaner and a wire and avoid having to take it all apart again
this is where I would look
