I measured my truck, about the same measurement. My only concern is they wont recline enough to be in a comfortable position without the seat being too close to the steering wheel.
It does look pretty tight in there! You can always stretch the cab. Good luck! Arno
The inside of this thing is no bigger than a mid 80s Niisan or Toyota PU.
69.5 A12 Bee, first purchased in 1976, car 169 on registry
69 Coronet R/T 440/4 spd
69 Coronet 500 Conv H code 383 4bbl/auto
37 Plymouth PU
Find your spot on earth and ride it.
