If you are running stock rockers you shouldn't need shims. If your push rods are too long buy shorter. Shims mess up the geometery of the rocker system. Shims should be beveled not even or you will have an oil pressure problem.
I'm not sure I agree with most of this....
I'm running stock rockers BUT I have altered where the head sits in relation to the cam. Buying pushrods .010" shorter doesn't make much sense to me compared to shimming the shafts to be honest. I would RATHER raise the shaft back up to where it should be.
CrAzYMoPaRGuY
