Just went out to the shop to pull off my t-fitting to the spray bar valve covers. The top of the fitting has a reducer that takes the hole size down to 9/64 the line that goes up and splits into 2 lines to fed the spray bar valve covers has a 3/32 hole in the fittings that screws down onto the 9/64 hole coming out of the block. It looks like it is already restricted enought.
Is there any need to still put a pipe plug in and drill out to 11/64 at the base of the fitting with the restriction it already has? THANKS!!!!!
