Quote: then how do you tell if its a 450 wheel with no part #
Once you get to know their characteristics you can spot one pretty quickly. If no tire is mounted is you'll see that the center is like this in depth, same as a rallye wheel. The later common 15x7's like from a Diplomat will be nowhere near as deep in the center.
